requesting DHP 1.0 or 1.5 tune binb file please
fst
Hi, I’m currently requesting for the DHP 1.0 or 1.5 starter bin file. I’m currently helping a local tune his car and would like a general starting point to get his modding started. Thus far I adjusted his tranny tables (kick down shifts, shift points raised, line pressure increased) but did not touch much on the Torque Management to help preserve the trans.
i left the spark and knock tables untouched along with the maf table, but richened the PE AFR command from 12.4 to 11.7. Left the PE vs RPM alone, as that’ll need a log file/scan and wideband to get better idea of the WOT fueling. The other reason for the starter bin file is to change the codes to no reporting for EGR and B1S2 amongst any other codes. Thanks in advance.
the local's car is basically stock other than wizair CAI. he has a stock downpipe with u-bend delete coming on next along with AL104s.
