Reprogram key fob
swed
Is here anyone how can help me. I need to repogram my key fob too my grand prix-90. I cant find how too do that. Pleas help me.
Try this:
Locate the black-and-white programming connector wire located in the right-hand side of the trunk. Pull back the trunk's lining to access it. On the end, you will find a terminal in a plastic connector. Place this against a bolt or the trunk latch. You will hear the locks cycle. Press any button on the remote, and listen for the locks to cycle again. Repeat this step for all remotes
These instructions were how I got mine to program (03 GP GT):
Enter the car and close all doors. In the fuse panel, remove the "MALL PGM" fuse. Put your key into the ignition, and turn to "ACC." Turn the key on and off within a second. Open and close the driver's door and listen for the chime that indicates you are in programming mode. Press and hold the LOCK and UNLOCK buttons for 14 seconds, listening for the chime. Wait 14 seconds for the second chime. Repeat this step for all additional remotes, remove the key, replace the fuse, and exit the car. You will have programmed the remotes.
These instructions are for 1994. That is the oldest I can find.
1. Locate the programming connector wire located in the RH trunk area.
You may have to pull back right side trunk trim on trunk wall to locate
the single black/white wire.
2. The programming connector wire should have one termial in the plastic
connector on end of black/white wire. Ground the terminal in the connector
to a nearby bolt or trunk latch.
Leave connector wire connected to ground through out procedure.
3. System will now lock and unlock doors automatically to indicate
programming mode has been activated.
4. Press any button on keyless remote. System will respond by locking
and unlocking doors one time to indicate successful programming.
5. Repeat step 4 for to program any additonal keyless remotes including
and existing keyless remotes. Do not remove ground wire between
programming of keyless remotes.
6. Disconnect programming connector wire from ground to exit programming
mode.
7. Test keyless remote(s).
