A 5lb slide hammer makes quick work removing the hub from the spindle, corrosion between the hub and spindle can make difficulty, so long as your hub has the acccess hole in the flange. Clean ALL corrosion from the spindle opening and mounting surface, this can take time, be sure not to remove material though.
After you are finished and ready to drive the car, your still not done. Go for a short, slow speed drive, maybe 4 miles, don't go over 45. Re-peat 3-4 times min. If you do a lot of slow short city driving anyway, than your ok. One thing you want to avoid is a first drive that includes a high speed, as this will heat the bearings and damage the grease. You want to "break-in" the hub bearing, excess heat from the new bearing during break-in can damage the grease and cause problems down the road in 30-50 thousand miles.
