replacement bose
mine have been off many times, still doing just fine.
more accurately describe what parts you're talking about so we can better answer.
basically, the window came out of the track. the track being the two plastic clips that the window got glued to from the factory and are the parts that physically pull it down. i was hoping to find something at a store, but i might see if a gm dealer has something.
all the speakers came to today, but the 4's dont fit in the stock mount. what should I do?
also where can i get those little plastic holding trees or whatever they are called, i can tell i will need them later
and for wiring, im gonna need some help
How does it not fit? Describe the fit issue.
You can get those xmas trees at your local parts store.
As for wiring, its positive to positive and negative to negative.
I wish there was a "Thanks for this not useful post" button... describe where its hitting and not letting it go in any further or take a picture or two.
read this post again please.
and yes, I will continue to quote it if you keep giving me the same response. We can't help you if you can't describe the issue or let us see it.
this is how the stock speaker sits
this is how the new ones do
dremel, hacksaw, reciprocating saw, i dunno what ever turns your crank. No seriously i would use a dremel.
did you have fun getting the door panel back on? i always manage to forget to put the handle back through. never fails.
Nah after about 8 or 10 times you start to have it down to a science. I can have my dash apart in like 30 seconds deck and center consle out too.
i'll hold you too that, i think i'm up to five on the passenger door lol. and because of not replacing the clips each time, i get i can have the panel off faster than i can go 0-60mph haha
getting the panel back on is cake
i need new xmas trees, also i have to pull it off again so i can get the torx bolts that fell when i tried screwing them in
