holorinhal
Well I just got finnished replacing the lower and upper intake gaskets,Got it all fired up and the elbow that goes into the intake is leaking. It is leaking around the hole and O-ring. I can see the water comming from ther. And when I shut it down I can see and hear it hissing out of the hole that the elbow fits into. It is not pouring out but it is enough to cause it to drip under the car. Also I replaced the t-stat and a new housing gasket, and it is lightly spraying out between the matting surfaces there. Has any one else ever experianced coolant spraying from the t-stat housing ,with a new gasket change?
Oh well I guess tomarrow I will pull the tentioner assymbly back off and try two more new elbows. Is there any tricks to ensure the elbows seal up and dont leak from new? thanks....Hal
