removing items to clean up the engine bay?
z3r0
i recently removed my windshield washer bottle (i have a 97)
and was recently thinking of moving the battery to the trunk and the fuse box to the inside of the pass fender
any thoughts on what else i could do?
i have a 97 gtp how do u remove the evap without throwin codes ive never heard of deletin it thats y im askin
can either have the codes deleted or run an o2 emulator. i plan to try the emulator first and see how that goes
YES. ^^^
One of the nicest mods I did to mine, was removing the Throttle body, and running the wire loom under it, after using some expensive as **** 3M electrical tape and heatshrink, made a WORLD of difference.
You'd also be amazed how easily you can do a minor wire tuck on the car, just start hiding wires.
Someone needs to seriously do a wire tuck on one of these cars. IM talking get rid or all the loom and tape and shrink wrap it like the others were talking then take the fenders off and run as much as you can through the fenders to hide it and also some of the vaccuume lines could be hid inside the wiper cowl if you felt like running new vac lines. This is seriously one of the things I evny the damn honda crowd for! :)
Also getting rid of all the metal brackets all over the place does a lot. I just put an engine in my 98 and I left off the alt brack and left some of the metal brackets off also. I still have the lift brackets tho. Should get rid of them soon too.
that would be something i would love to do to mine is a wire tuck. Some of the nicest engine bays in the world are tucked. My civic was a b**** to do though
nah, it apparently ingested metal, it was royally ****ed... Nasty wear on the rod bearings, 3 chipped pistons, and plenty of metal in the oil pan
i'd like to see the heat shrinked ones? also where do you get that much heat shrink and are you guys removing pins to do this?
