removing dome light housing
2000GTP
were putting LED dome lights in my friends 01 GTP. how do you remove the dome light housing to get the bulbs in there?
Its really tricky, you pull the back of it (closest to you) down a little so it un-clips, then you kind of twist it out, your going to have to play with it for a while. Keep in mind there is a plug there and it will probably get snagged on the inside of your headliner.
