where can i get a good quality rebuilt compressor at a reasonable price? which rebuilt compressors should i keep away from? how easy is it to replace the compressor?
if your compressor went, you might have metal shavings in your lines, as well as blocking your orifice tube. a/c is the one thing i won't do myself, i'd rather sweat with the wind blowing than run around an a/c system fixing problem after problem.
my advice is to take it to a shop if you aren't experienced.
Replacing the a/c compressor is a rather simple process, but it just is somewhat time consuming from beginning to end. After removing the accessory belt, the a/c lines and then the compressor. You have to replace the compressor, the a/c lines, the accessory belt and then refill your system.
is the compressor removed from the top or bottom. do i have to remove the idler pulley, tensioner and brackets. i am looking for a more step by step instructions.
If it's anything like my 2000, it's cake. I got to it from the wheel well and underneath, tool like MAYBE a half hour at the most. Like the others said there is a lot more to it than just replacing the compressor, I hope you know. I spent a couple weeks learning and did it myself and I'm glad I did. I bought a set of manifold gauges and a vacuum pump from harbour freight for like 130 bucks, now I don't have to pay someone.
Yes, Take it to the shop first and have them recover what is left for r134a in the system, then replace the compressor, then go back to the shop and have them refill it.
