Scottydoggs
Killa Bee
some of the stuff on my slow screen. its over loaded, i have other pages with just KR.
the boost was tim's post of his t app screen shot. lol
Ya I had a vacuum leak under the dash and my 02 sensor was bad so.my trims and everything was wacked. I just posted that for him to.see what I do with my gauges on torque..lol..sorry didnt mean to confuse anyone.
Sent from my SCH-I545 using Tapatalk
Thanks. That car is messed up as well.
Timing is low, but without knowing if KR logging via Torque is actually working, or without seeing the bin/hpt of what's on your PCM, we can't know for sure.
These snap shots don't help that much either. You need a log with multiple data points.
Have you checked compression? Checked if the cooling system holds 15 PSI?
I ask because the integrity of the cooling system is in question because you're not holding a solid temperature and recent major mechanical work was performed. These two checks would be an assurance that your work is sound, and the problem lies elsewhere.
Did you solve the misfire issue yet?
You're also doing no one any favours by having so many threads and cross posting on multiple forums. It makes it more difficult to keep track of what specific remedies you've tried, and with what results. Without that, making suggestions as to what to check is difficult and will result in what you saw on the first page.
load the misfire gauge if you can on the T app. see if it shows any. cause it seems like bad misfires to me. ignition related some how.
could be a bad wire on the icm harness, like you pinched one, or by the pcm. they like to wear through on the a/c lines.
if its worse when hot the icm could also be bad....i know i know it ran on the other car, f that, test it. its free at auto zone. icm's go bad. even seen em test good and still be bad. so maybe try a junk yard one.
