Red Halo's
You can buy them for your fogs. I have them :D Look up the seller "FogLightKing" on eBay.
The fog lights are called autopia. You can get them with multicolor led halos. Mine change 7 diff colors i believe.
Get the LED (not CCFL) spyder projection ones of your choice, fix the bouncing issue they are prone to having. Do the LED rewire with a red LED in each one to get the red coloring you want.
easiest way to do it but will cost you
man, if you had to get aftermarket tails, why did you get the ugly chrome ones instead of the nice led ones?...
and what tlsheff said is correct. just bake them and pry them open.
they are but I don't think you can change out anything in them to make the halos red :confused:
Ive seen a writeup on changing the led out for different color options on the led ones
Made it for the fog lights behind my grill as you can see but you could use whatever color you wanted.
It can easily be done look it up on youtube. it shows u how to make the halo rings and u can find vids of bakeing the lenses to open them up.:th_jester:
