This started out as a minor issue, where the car would stutter, but has gotten worse the more I try to fix it.
The car is a 1998 Pontiac Grand Prix 3.1 SE
Currently if I idle the car at 2000 RPM, it will stutter and buck, and sometimes stall. If I attempt to drive the car, same thing. It's virtually impossible to drive.
I've replaced:
Spark Plugs & Wires
Air Filter
Crankshaft Position Sensor
Fuel Pressure Regulator
Fuel Filter
Harmonic Balancer (it was wobbling, so it seemed a good idea)
I've run fuel injector cleaner through it
I've put HEET in the gas tank thinking bad gas
I haven't yet replaced the Fuel Pump because that's a last resort, it's more expensive than all the stuff above. The SES light is not on.
I connected a Fuel Pressure sensor, and disconnected the vacuum hose from the regulator and plugged the hose, then idled it at 2000 RPM, and the gauge didn't move much when it stuttered, etc, it just flickered. When it went to stall, it dropped a little. I thought it strange that the lights inside flickered, etc, but it only dropped to 1000 RPM, not stalled. It sounds like it might be an electrical problem, maybe? I'm tired of replacing parts and not gettin anywhere.
What I *WANT* to do is take a match to it and enjoy the firery glow.
Suggestions? Comments? Thoughts?
Thanks for your time,
Robert
I've replaced:
Spark Plugs & Wires
Air Filter
Fuel Filter
Robert
