rattle on accelleration
I'm thinking cracked or loose flexplate. If it doesn't do it in park or neutral then it has to be tranny related. The torque converter isn't engaged when not in gear. Its also bolted to the flexplate.
thanks man ! hey u have an aol account ? or just an email so i can keep in touch a quicker way ,,, you have been helpful ,, i would like ti be able to contact you if i have any questions.
.Possible flexplate issue? Remove your flexplate cover, rotate it to make sure it isn't cracked. Check the bolts also. Is it a metallic rattle or more like a ticking? A bad flex joint can cause a ticking sound when accelerating.
x2 mine had the same problem and it turned out that two of my convertor bolts were loose.
