QUICK QUESTION: Mysterious Plug
dbextreme
I am hooking up my new harness and found this plug under my "battery tray". Nothing goes to it and looking at it, it appears nothing has been hooked to it. It's as dusty inside as it is out. It's a three pin plug with only two pins in it. It appears to be coming out of the headlight harness right before the fuse panel between the battery and strut tower. Please Help!!!
I have the same plug and it's never been used. I think it's a factory accessory plug of some sort...maybe remote starter or something.
Have you found the one on the back of the motor by the fire wall yet? Another mystery plug?
Now I'm going to spend a hour looking for it.. LMAO
I do wonder what the plug by the battery is for though.. Might do some calling around tomorrow to see what it's to..
i found one plug under my upper rad support, not sure what it is but it seems to never have been hooked up
yeah that one I found on mine while I was hooking up my HID's... 2 pin plug I believe... if I look down where the hood latch is I can see it...
Do you have digital hvac? Or digital rear view that shows temp? Cuz that's for the ambient air temp outside.
I was confused at what it was too, so I looked at alldata and that's what it says it is.
