Question on a 3800
KwazrollinZ28GTP
it's out of a camaro, but will work on a Grand prix/regal/monte carlo. etc..
I thought it had a rod knock, i was dumb, bought a brand new motor, i checked the bearings on this, there good, i'd still replace them while the motors out, but if your strapped they'd work, it had a blown head gasket and exhaust manifold leak.
so now it needs head gaskets, the bolts on the bearings tightened, and gaskets for oil pan, Question is what is this worth, or should i scrap it, I don't really need it since the heads are not injector ported so no boost, but its still in great shape and had 50psi oil at idle so it wasn't bad.
Bottom line what should i post it for? thats if anyone in michigan would even want it. :)
and yes thats a FWD oil filter adapter, i used the RWD one off this motor onto the new motor ;)
You can try and sell them. A turbo guy might wan them, also pull and sell the rockers to someone for a core charge, if they want to keep theirs.
