Question about current topswap
BlackGT97
I am currently topswapping my 98GT, I have it down to the block right now. But it seems that from 97-99 they used the same MAP sensor for both the SC and NA motors, but in 2000 they switched the Map sensor for the SC version. So is it ok to run the MAP sensor off of my NA motor?
Well the part numbers from autozone are the same, but i checked again and they do have the 1 bar map listed for the SC model too so IDK lol
then that parts listing is probably incorrect.
The L67 received the brick 2 bar MAP.
The L36 had one in the UIM.
You need the right MAP for the BIN that's on your PCM.
A 1 bar MAP cannot read past 1 bar absolute, which is zero boost.
Find out what bin will be on your pcm, then buy the MAP sensor for that car.
