basic hand tools. leave the ac compressor off but lay it on the engine cradle, i always laeve the alt and bracket off too. drop it in. 13mm on the power steering pump, 13mm on alt bracker and alt, 15mm on lower engine mount, 18mm on converter bolts, 18mm on bellhousing bolts, 15mm on ac compressor, 15 mm on starter. 13mm on the b terminal on the starter, 8mm on the s terminal. 10mm for the dust sheild that goes around the converter. 13mm on the downpipe. 13 mm on trans to engine block bracket. plug in all your sensors, maf, tps, iat, oil level sensor, oil sending unit, knock sensors, etc. put the cross over on, 13mm. put the belt on double check EVERTHING. change the oil and hook the negative battery cable back up. start it
