put 5w-30 in 10w-30
kind153
1998 gt.
got an oil change today...as i was leaving i notice they put 5w 30 instead of 10w 30. I drove 3 miles..should I be worried?
Nope. Read your manual. Either will work, depending on temperatures where you live...one can be better or the other.
checked my manual..am i misled by the chart to think i'd be better with 10w-30?
I'm in KS and the weather in summer here has been like 45~94F.
yes you should. its kind of like if you're always synthetic and someone puts in coventional. you're ok for a little while but make sure u put in synthetic next time lol
Thats not true you can switch and your motor will never know the differance. Like running a syn. blend which is a mixture of both oils. To the OP the only differance between 5w-30 and 10w-30 is that 5w-30 will flow better in below 0 temps. during a cold start up. After both oils are up to temp they are the same.
ok..didn't mean to start any debate..but thanks for all inputs.
and no, not having a garage and summer temp doesn't make it look so fun to me;
You sir win.
