SyntheticShield
Then you would be wasting your time and money pulling out a good set of iridium plugs. Where do people come up with this stuff? And since the ICM has a current limiting circuit putting lower resitance wires on if your OEM's are in good condition is a waste as well.
First, it is a known fact that exotic metals such as iridium and platinum do not conduct electricity as well as copper. All the iridium plugs do is allow a fine wire electrode that helps with reducing the voltage needed to jump the gap. Platinum is mainly for longevity.
Secondly, I dont consider it a waste to put in lower resistance wires. Have you ever measured the resistance of the OEM wires? Have you then measured the resistance of aftermarket wires, particularly MSD wires? Then have you done the math to see how much voltage is lost in OEM wires? I have and its considerable. Do you also know whether or not you would exceed the current limiting of the ICM with lower resistance wires?
You're expecting horsepower gains from plugs and wires. And while it does do that, its not significant and usually is better taken advantage of with timing adjustments. But the big thing is ignition system efficiency. Getting more of the power of the coils actually to the plugs. That can help with fuel economy among other things.
Additionally, while I do not buy into the Pulstar plugs, plasma ignitions are not all that new. So the concept of the Pulstars are sound, but the numbers and such they use is just not possible in our ignition set up and system voltage.
