bigdawg2020
Hello everyone. 02 grand prix, sounds like spun bearing noise in park and neutral. Goes
away when you put it in gear but does not move, does not move in reverse either.
Took passenger side of tranny off pulled out final drive gear assembly. And took a few other things
out. One question is. The aluminum housing I took off, there is metal stuck around the
vss. Where the seal is, right behind that I believes there is suppose to be a bushing
there. I need to know if one is suppose to be there, also I don't think that would
be the reason it won't go in gear
