Timing should peak at the top of the power band and drop off as you redline. Most people just run the same the entire way thru
Apparently increasing timing as you go up is a better way to do it.
Depends a lot on the fuel your are running as well. When guys are trying to get the most out of their car, they are running 100-110 octane fuels, lean as hell on small pulleys. If people ran 21* timing across the board they started popping head gaskets, so they would run 18* at 4500 rpms and go up in steps from there, some would even go past 24. Obviously you could not do this on 91 octane, but some of the same theories may apply. Also 4000 rpms is about the range that the car is under the highest load, so timing there is not going to be the highest.
Not only will octane be a factor but, with ethonal being thrown in there, its gonna matter what KIND of fuel you run aswell...
Since i switched, I cant MAKE my car knock...
Saying flat out that 20 deg of Timing will chip a piston is bad advice in my opinion. It deals more with AF ratio I would say then with the specific timing. If your too lean yeah you could have issues... Unless the pistons are that brittle? And the combustion makes too much pressure... But if that were the case everyone would be chipping pistons on higher HP setups and. Don't think this is the case.
I wish e85 was more redly available in the rural communities and interstates. There's a station a block from my house that sells it but i'm too afraid to convert. I don't want to be stranded somewhere.
They start popping headgaskets before they chip a piston on 110 leaded. People can see their timing easily so they like to focus on that, but a wideband is what few have, so street cars running 91 pump and trying to run 20* timing year round is what they label as unsafe and prone to chipping a piston. If people have no idea what their actual AFR is, then it's most likely good advice saying 20* is unsafe year around. Some can get away with it, some don't.
