Pros and cons of going catless
chris99gtp
GTP Level Member
Putting on sd headers as i write this. The cat almost looks new. Is it worth reaming out and going catless with the defouler trick or should I just put the cat back In. do I make any gains by going catless?
Thanks
Chris
pros being catless = better flow, release more powaa. cons being catless = your exhaust smells worse, and you have to deal with the O2. when it comes down to it theres not much difference, its all in whatever helps you sleep at night
