Proper brake bed in procedure.
DirtDog
Disclaimer: I stole this from GMLS4
Credit to 06monteSS
How to "bed-in" your new brakes/rotors...
Brake Pad and Rotor Bed-In Procedures - Article 1 - Zeckhausen Racing
Bedding allows your brakes to reach their full potential. *Until they are bedded, your brakes simply do not work as well as they can. *If you've installed a big brake kit, changed your pads and rotors, or even purchased a brand new car, you should set aside time to bed the brakes according to the instructions below. *Proper bedding improves pedal feel, reduces or eliminates brake squeal, prevents (and often cures) brake judder, reduces brake dust, and extends the life of your pads and rotors.
Caution:*Immediately after installing new pads, rotors or a big brake kit, the first few applications of the brakes will result in very little braking power. *Gently use the brakes a few times at low speed in order to build up some grip before blasting down the road at high speed. *Otherwise, you may be in for a nasty surprise the first time you hit the brakes at 60 mph.
If you have just installed rotors with zinc or cadmium plating, or if the rotors have an anti-corrosion phosphate coating, you should postpone the bedding process until normal driving has allowed your brake pads to polish the rotors clean and removed all traces of the plating or coating. *If your new brake rotors have an oily anti-corrosion coating, you should clean this off thoroughly with brake cleaning spray and/or hot soapy water.
Read and understand these bedding instructions completely before starting. *If you have questions, give us a call or email. *Do not substitute higher speeds for the 60mph called for in these instructions. *The heat in your brakes goes up exponentially as you increase the speed from which you brake. *If you make repeated stops from 80 or 90mph with street pads, you will overheat the brakes and may end up having to replace pads and/or rotors.
When following these instructions, avoid other vehicles. *Bedding is often best done early in the morning, when traffic is light, since other drivers will have no idea what you are up to and may respond in a variety of ways ranging from fear to curiosity to aggression. *A police officer will probably not understand when you try to explain why you were driving erratically! *Zeckhausen Racing does not endorse speeding on public roads and takes no responsibility for any injuries or tickets you may receive while following these instructions. *Use common sense!
1.*- From 60mph, gently apply the brakes a couple of times to bring them up to operating temperature. *This prevents you from thermally shocking the rotors and pads in the next steps.
2.*- Make eight to ten near-stops from 60mph to about 10-15 mph. Do it HARD by pressing the brakes firmly, but do not lock the wheels or engage ABS. *At the end of each slowdown, immediately accelerate back to 60mph and then apply the brakes again. *DO NOT COME TO A COMPLETE STOP!**If you stop completely and sit with your foot on the brake pedal, you will imprint pad material onto the hot rotors, which could lead to vibration and uneven braking.
3.*- The brakes may begin to fade after the 7th or 8th near-stop. This fade will stabilize, but not completely go away until the brakes have fully cooled. *A strong smell from the brakes, and even some smoke, is normal.
4.*- After the last near-stop, accelerate back up to speed and cruise for a while, using the brakes as little as possible. *The brakes need only a few minutes to cool down. *Try not to become trapped in traffic or come to a complete stop while the brakes are still very hot.
5.*- If full race pads, such as Hawk DTC-70 or Performance Friction PFC01 are being used, add four near-stops from 80 to 10 mph.
After the break-in cycle, there should be a slight blue tint and a light gray film on the rotor face. The blue tint tells you the rotor has reached break-in temperature and the gray film is pad material starting to transfer onto the rotor face. This is what you are looking for. *The best braking occurs when there is an even layer of of pad material deposited across the rotors. *This minimizes squealing, increases braking torque, and maximizes pad and rotor life.
After the first break in cycle shown above, the brakes may still not be fully broken in. *A second bed-in cycle,*AFTER*the brakes have cooled down fully from the first cycle, may be necessary before the brakes really start to perform well. *This is especially true if you have installed new pads on old rotors, since the pads need time to conform to the old rotor wear pattern. *If you've just installed a big brake kit, the pedal travel may not feel as firm as you expected. *After the second cycle, the pedal will become noticeably firmer. *If necessary, bleed the brakes to improve pedal firmness.
Brake Pad and Rotor Bed-In Procedures - Article 2 - TireRack
All brake pads must be bedded-in with the rotor they will be used against to maximize brake performance. The bedding-in process involves a gradual build up of heat in the rotors and pad compound. This process will lay down a thin layer of transfer film on to the rotor surface. Following the bed-in procedures provided by the manufacturer will assure a smooth, even layer of transfer film on the rotor and will minimize brake judder. Here are a few things to keep in mind when installing new rotors and pads:
When installing new pads, the rotors should be new or at least resurfaced to remove any transfer film from the previous set of brake pads.
It is critical that the installer clean any rust, scale, or debris from the hub mounting surface thoroughly and check it for excessive run-out with a dial indicator gauge before installing the rotor.
The new rotor should also be checked for excessive run-out using a dial indicator gauge before the caliper and pads are installed. If a rotor has excessive run-out of over .004" (.10mm) it should be replaced.
If your new rotor has excessive run-out, please contact our customer service department for a replacement rotor. Do not install and drive using the rotor! Rotor manufacturers will not warranty a used rotor for excessive run-out. Running with excessive run-out on the hub or rotor will cause vibration issues.
Failure to follow these procedures may result in brake judder, excessive noise, or other difficulties in bedding-in the new brake pads. The pads need a fresh surface to lay down an even transfer film. Residue from the previous pad compound on the surface or an irregular surface on a used rotor will cause the pads to grip-slip-grip-slip as they pass over the rotor surface under pressure. The resulting vibration will cause noise and telegraph vibrations through the suspension and steering wheel. This vibration is known as brake judder or brake shimmy. This is typically caused by an uneven transfer film on the rotor surface or an uneven surface on the rotor not allowing that transfer film to develop evenly. This is often misdiagnosed as a warped rotor.
Bedding-in new pads and rotors should be done carefully and slowly.*Rapid heat build up in the brake system can lead to warped rotors and or glazed brake pads. Most brake pad compounds will take up to 300-400 miles to fully develop an even transfer film on the rotors. Following are the recommended bed-in procedures from each manufacturer:
AKEBONO
400 to 500 miles of moderate driving is recommended. Consumer should avoid heavy braking during this period.
ATE
BREMBO Gran Turismo
In a safe area, apply brakes moderately from 60mph to 30mph and then drive approximately 1/2 mile to allow the brakes to cool. Repeat this procedure approximately 30 times.
HAWK
After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph. Do not allow the vehicle to come to a complete stop.When completed with this process, park the vehicle and allow the brakes to cool completely before driving on them again. Do not engage the parking brake until after this cooling process is compete.
POWER SLOT
Follow the brake pad manufacturer's recommended break-in procedure taking care not to produce excessive heat in the system. Avoid heavy braking for the first 400-500 miles.
SATISFIED
its best most of the time to just drive the car real nice and easy, no hard braking. baby them for a few days and they work fine.
Yea. Let me finish fixing the post. I used this procedure for my brakes and worked great.
