    TIPS:
Projectors that will fit 9007 LED bulbs
00RedfireGT
Donating User
I am looking for a set of headlight housings that will work with my 9007 LED bulbs, installed them in my stock housing and they are bright but they would look so much better with projectors, don't have to be perfect but in pretty good condition, let me know, thanks
A projector that takes a 9007 bulb? Don't think they exist. And if they do, the projector would probably be to large to fit in our housings.
Never seen one unless maybe you're custom fitting an oem projector. Usually just best to grind down the bulb seat on the headlight and install a mini H1 projector or something similar and use h1 bulbs.
They don't exist. Projectors will usually be an H-series bulb like an H1 or H7. That is unless its high intensity discharge (hid), then it will most likely be a D2S
