Projector Hi-Beams
There are two adjustment screws on our headlights.
They aim the headlights.
One screw is for up/down and other is side to side. Use those screws to move the projector. You can close the gap between the headlight and the fender (by grill) by turning one of the screws.
But you don't want to change that gap. Those projectors already cross bad enough. If you screw them 'in' so that gap is smaller, they cross like all hell. The actual projector is mounted at a crappy angle.
the mini moto or w/e projectors are a direct swap from the sonar projectors. Good luck getting the lens off though.
I have the exact headlights, hid lows. I have no problem seeing at night, yes I need to adjust the height I know.
Uploaded with ImageShack.us
Mine aren't crossed much if at all. The turn signal part of the lights? Well those aren't flush with the fender, they are set in nearly an inch, pushing the sides in and leaving the front where it is, moved the light just enough so they don't cross.
Could I just get a new set of OEM housings and put the guts from these into those as a "retrofit"?
