16MustangVet
Better track prep will be 10s im all but certian of that.
Again all bull**** aside its nice to see straight forward results!
Can't complain about the track too much. I know it's not the quickest track, I was too lazy to drive 3 hours to the best one.Better track prep will be 10s im all but certian of that.
Hek of a nice run there, congrats!
I've been to Luskville dragway before, we ran an 1/8 mile race in our Pro Mod 02 Camaro there back in 05 and I doubt it's changed much.
Definetly not a "National Event" type track, very uneven surface and narrow groove there, had to pull alot of timing and do some work in the clutch can to get it down that track. Guy we were running against didn't know what the word "Lift" meant
Safe to say I see that car running 10's on a "good" track
In my case, it ran pretty well, slipping the converter a lot but pulling good. in the last few passes, it started to have a slight shudder from the trans when going into 3rd gear.we shoulda ran 10's years ago if the trans didnt fight us the whole way
Nice runs... I am guessing you are banking on the injectors just being static and never stopping fuel flow and the race gas
keep things from popping?
Also how much life you get left in that little guy of a turbo? (I haven't read all the posts here)...
My first run in the 10's was a 10.8 @ 19psi and not so great of launch... but have been able to sqweak out 10.9's on 15psi
when I fudge the HKS controller to wrong setting.
500-600lbs out of these cars allows them to run some pretty good times with horribly not alot of stuff. I have a ST5 cam,
and some yocal head work, but the short block is a 95/96 with over 200k miles on it.
Be interesting to see what the trans inside looks like. I put on over 100 passes in 2013, majority in the 10s, and there wasn't
a lot of wear at all, just a little on 3rd, and PRJ had 4th gear disabled. The ZZP converter is most likely shot tho.
I also didn't get into the 1.5x 60 foots until I started launching off the line at 10psi and having the m&h slicks down to about 10-10.5 psi.
I felt that day 1.4's could have been done, if they had glued.. rained before track opened and was test and tune.
But after that day, is when the converter side to whine and called it a year.
My setup is roughly around the 3000-3050 range with the cage and no driver. Like to knock another 100-150lbs out and still have it look
mostly stock inside.
The Turbo Compressor is fairly large, close to a GT35 in terms of flow. But the turbine side is small, and at the power I am right now, it's slowing my down.
It's a great street turbo at 15-18 psi of boost. Any more than 20 psi is diminishing returns.
Injectors are not static. Making the tune richer would actually make it richer. They are not running at 100% actual duty.
I raised base FP to 60 psi and am running leanish now but now run 100% race fuel. Junk Torco race fuel since that's what I have in stock.
If I ever go back it will be with VP C16.
I have no suspension mod, no cable nothing.
OOOOOOO glass link thanks!
Not sure if zachs old gutter car had them done already or not?
Hope so then I wont have too!
Thanks!!
Where do you find the weight specs? Do they have them or just call?
1200ish for whole car, hmm light car with light replacement glass = NO MEGA BUCK TRANS PARTS??
1200 ehh that's what a little less than a 1inch GMR chain cost?
The real question is exactly how much weight savings is a full car worth of the 3/16"? Thinner cost less obviously.....
Now your going to get me calling glass shops for stock weight estimates and then ill just figure off the 50% estimate.
Thank you, I love this particular model. Interior is real nice too, full options.Very nice
