chrisLB
Ok I've got all my other problems mostly solved except the tranny... I swapped a 02 L67 into my 97 L67 and before the swap both lights worked on the dash showing what if your in park and what not and both car you could press the break and shif from park and turn the key all the way back... Now I can't I used the 98 wiring and ECM and even tried a back up ECM I have so it's not that... Any ideas what I can check? Wires I may have damaged in the swap that would cause this or a relay? It drives fine other then the one tranny code that comes up from time to te and I can't remember the code number off hand... Any thoughts in what I can check would be grate...thanks guys
