SF9777
Ok so my 07 GP base has a problem of the Hi beam turning on when i use the turn signals. This has been going on since last summer, we just took out the hi beam bulbs since we dont really need em. Now we want to fix it so we can use the hi beam, but not the Hi beam just stays on at night and turns off when i gently pull the stick forward towards me but when i let go it turns back on and stays on. Before we just tapped the stick inward into where its plugged in and it would turn off but when i use the turn signal again it would turn back on again. We took off the bulbs since it would look like we were signaling other people, now we kind want to use them again so what is really wrong with it? Is it the multifunction switch or what, also how do we take it out, do we just unscrew the top and bottom and take it out then unplug the switch? We want to clean it and could that help possibly solve the problem?
Thanks in Advance
(I posted this exact same thread in the General Discussion section and i read the guidelines sticky and found out its not to be there so i put it here. If someone can delete the other one would be great, thanks)
Thanks in Advance
