problem after header install
dmahlikGT
After my friend and I installed my SD headers I took it for quick drive. After roughly 2 min car started surging and almost dying. So came back and we scanned it, and codes p0136 and p0141 popped up. Both point to front bank o2 sensor. I can't remember anything bad I did other then maybe when I twisted it trying to reinstall I may have damaged it? But then today same thing occurred but 3 other codes popped up p0030,0131, and 0135. Same issue car surges for a few and acts like it wants to die. I also have the zzp o2 sensor extension for the front, could that be defective or should I just replace the front o2 sensor?
Did you use an extension harness or did you make your own?
oops missed the part where you said you had the extension harness sorry
You might have damaged the wires in the 02 sensor like you are thinking, that is the only thing I can really think of. Just run to Napa and get a new Denso 02 sensor.
zyea ill do that. It may have been when i twisted it i forgot to unhook from original harness and the wires twisted and may have damaged some. I also sprayed pb blast on it to get it off i dont know if that matters. didnt get too much on sensor though.
I sprayed a bunch of pb blaster as well n didn't have problems, may have twisted a wire loose, take it off n check it before ya buy a new one even.
well its not stupid since i didnt exactly double check to.make sure it wasnt touching.i did have it tucked somewhere since it has so much extra slack. ill double check soon.
Had to replace my front o2 after my header install just grab a new one clear the codes and go from there
Found the issue,it was my extension harness being welded/melted from touching headers lol. Good call iceman.
Do i need to necessarily solder? I was told i can get away by just twisting them good and use electrical tape plus heat shrink,and would it be ok if i ran my front o2 unplugged for a few days til i resolve this? i work 4 days straight.
Glad you got it sorted out... Mine acted funny after header install.. Turned out mine was sitting on my headers too, that's why I asked.
oh dear lord, who ever told you that, find them, then smack them lol
HF iron is like 3 bucks, (10 at sears) solder at the shack is 5 bucks, you want flux core solder, its thin and in a tube. then HF shrink tubes are 3 bucks for a huge ass assorted box. or 5 or so at the shack for way less of them.
you tube show to solder, theres nothing to it.
Aight guys lol. But again i won't have much time til the end of the week so could i get away with having my o2 unplugged til then?
dont think your engine will like that to much. you could do the twist and tape as a temp fix till you can do it the right way later this week.
