Power Wire for Amp
So if I just wanted to drill through the firewall where would be the best place to drill to avoid missing wires, etc.
the area i drilled, under the windshield was wire free, but i still only let the tip of the drill bit go through. its also a dry area, no water gets under there.
i dont know i cant assume anything here, once i do im wrong, tell this guy to drill somewhere that isnt safe, does he even realize what a gromment is or should we let him find out down the road.
i know right? And its 6ga, come on now. you can get that through anything. my speaker wire is almost 6 ga
pics from this thread http://www.grandprixforums.net/water-floorboard-take-2-permanent-fix-6961.html
i drilled on the left side theres a divider, left and right side. so side closest to the fender, but next to the divider.
lol i asked and it took this long to respon, dude just run that little itty bitty baby wire through the groment on the drivers side.
Also I was unable to get the wire through either groment. I'd honestly be surprised if I could get my signal wire through the one. I think my best bet is to just drill through the firewall.
no no no, get a phillips screw driveer and poke it through, like man if i can get the 00 awg wire in thats more than 5 sizes bigger than yours. come on now.
It said it in the first post and I didn't see your post asking until just now. I'll try the one on the driver's side
I'll check again but I'm pretty sure. All the wires leading there form a big bunch that completely fill some sort of tubing they are being fed through
Matt...
Before you drill. pull back the carpet at the passengerside floor. Find the big square grommet thing I'm talking about. Now take a flathead and pry at the lines that you see in it. It's techincally just pushed in there. Once you have the 3/4" this piece out of the way, put your wire through the thin boot that's on the outside (a slice with a razor knife should work) then position the wire reasonably and push that piece you pulled out ....back into place and cut if needed.
I've drilled through that piece, I've cut it ..I've pulled it out and stuffed it back in ... all work. I was trying to keep you with the best method.
ive done countless gp power wires and have run them all the same way without issue. dont see how you or your car is special or maybe you are special........ed.
