power windows
Dee23
My front two Windows work fine(motor n regulator) but the front windows are power windows so they're supposed to come down automatically on the press of the switch.
Mines don't, sometimes it will if i sit there and play with it but otherwise no.
If the regulator and motor works, what can keep the windows from coming down automatically as they should?
00' buick GS
time for new buttons in the door. only the d/s window does express down.
its one of them things id not fix personally. but you can buy just new window switches new on ebay.
because express down is just a locking switch/breaker.
when its down your motor stalls and it pops the breaker. if yours is new enough and its all BCM controlled its still happening but through a differnt means.
much like making sure i dont hold the steering against the lock, i dont hold the motors under stall by pressing the switch longer than needed, i shutoff high loads before shutting the car off and turn em off only after the ign switch is in the ON position.
its all wear and tear
probably explains why my 97 gtp is at 214k with nothing changed (well vise grips hold the drivers rear window up) but hey, ****it 3$ at HF vs 60$
