power window question
mngtp
I am wondering if its normal for the windows on the 2 door gp's to roll up slowly? Both windows seem to go up slowly but the passenger window is a lot slower than the driver side and sometimes it stops before going all of the way up, when it stops I have to let it down a little and try rolling it up again. The windows have be rolled up one at a time otherwise if they are done at the same time they barely move. Any ideas what could cause this?
the sliders and the regulators i bet are dry and dirty, you can pull the door skin and lube up all the moving parts, i like to use graphite spray, but silicon spray white lithium grease all that stuff works.
or the motors are starting to die. when operating both windows they will go slower than one at a time, but what you are saying sounds like you need a lube job.
Thanks. I will have to try lubing them up. When I say they move slowly when I roll them up together, I mean they barely move at all. Thanks again for the help.
