(Power Stop) red powder coated calipers
Pure2sin
Was just looking at some new calipers and saw these:
(Reman) Red powder coated dual piston calipers.
getimage.php
They are $54.79 a piece on Rockuato.com right now.
Search under 2006-2013 Impala calipers. They use the same knuckle as some (if not all) W-body's, so they should bolt right up. The only difference is that you would obviously need new pads and rotors.
You can get the rears also:
Rear- $62.79 a piece.
getimage.php
I priced it all out and it was around $440 with everything, Brakemotive rotors and ceramic pads. Although it might a good time to replace the brake lines also and get some more fluid.
The 06+ Imp's run 12" front rotors. This is the route I'm going instead of the fbody upgrade, except I'm going to go with R1 E-line solid rotors and installing SS lines up front. I'll be grabbing mine from a JY though. Don't want red calipers on a dark blue car, lol...
Yeah I was thinking about the JY myself. Although on my car red would look good and powder coat instead of paint would be nice too.
