sn95gt50
2008 Grand Prix
Power door locks started not working intermittently sometimes one will work sometimes all sometimes none.
Trying to diagnose, when you hit lock or unlock (remote or door switch) when they don't work, you will see them move just a little like they want to come up but they won't. We have also noticed a correlation between heat, if it is hot outside they are much less likely to work and when it is cooler (night) they are more likely to work.
This leads me to believe it is probably the actuators getting weak, but, want to be sure before throwing parts at it. I assume that the actuators get either no volts or 12 volts, is this correct. If so, I should be able to test to see if they are getting the full 12 volts at any time.
Any advice would be appreciated.
Thanks,
John
Thanks,
John
