Post Whoring Thread 2.0- DON'T DELETE THIS ONE
Status
Not open for further replies.
o hare supposed to of be pretty hard to get to with all the rain, I know I have a conference and we were sent emails advising us.
So....parts I have ordered in the past few weeks:
Qty: 1 - Item #: 4925822G - Desc: Clutch Slave Cylinder
Qty: 3 - Item #: 8114107 - Desc: Engine Coolant Antifreeze (Purple)
Qty: 1 - Item #: 0892930 - Desc: Valve Cover Gasket
Qty: 1 - Item #: 101K10054 - Desc: Turbocharger Gasket Kit
Qty: 1 - Item #: 101K10098 - Desc: Engine Dress Up Kit (Stainless
Qty: 1 - Item #: 4383956 - Desc: A/C Refill Cap
Qty: 4 - Item #: 4493433 - Desc: Window Roller
Qty: 1 - Item #: 4758140 - Desc: A/C Valve Cap
Qty: 1 - Item #: 5063714 - Desc: Transmission Mount - Upper
Qty: 1 - Item #: 5239173 - Desc: Engine Mount - Rear
Qty: 1 - Item #: 5239314 - Desc: Steering Tie Rod End - Drivers
Qty: 1 - Item #: 5239322 - Desc: Steering Tie Rod End - Passeng
Qty: 1 - Item #: 55557709 - Desc: Oil Trap Hose
Qty: 1 - Item #: 55559428 - Desc: Coolant Return Tube
Qty: 1 - Item #: 55559429 - Desc: Oil Inlet Tube
Qty: 1 - Item #: 55559431 - Desc: Coolant Pipe (Inlet)
Qty: 1 - Item #: 55559479 - Desc: Pipe Clamp (turbo inlet)
Qty: 1 - Item #: 55560445 - Desc: Crankcase Vent Hose (Exits Bot
Qty: 1 - Item #: 55560602 - Desc: Cobra Pipe (Air Tube)
Qty: 1 - Item #: 55564966 - Desc: Turbocharger
Qty: 1 - Item #: 5955919 - Desc: Oil Trap Hose
Qty: 1 - Item #: 5955927 - Desc: Oil Trap Hose
Qty: 1 - Item #: 5961610 - Desc: Oil Trap Hose
Qty: 2 - Item #: 65340118 - Desc: Sway Bar End Link - Rear
Qty: 1 - Item #: 9194242 - Desc: Thermostat Kit (88 Degree)
Qty: 5 - Item #: 93165290 - Desc: Manual Trans Fluid (Gear Oil)
Qty: 1 - Item #: AL0813CORE - Desc: Core Charge
Qty: 1 - Item #: AL0813X - Desc: Alternator (140a) (Rebuilt)
Qty: 1 - Item #: TSHIRT019 - Desc: SAAB Thing Tee (XLarge)
1 55557240 AFT 95 1999-2009 Crank Seal Flywheel side
1 55559824 AFT 95 1999-2009 Oil Pressure Switch
1 4580346 OES 95 2000-2009 Clutch Kit 9.5in Aero Includes pressure plate/disc
1 151094200 AFT 95 1999-2010 Frame Bushing Kit w/washers
1 KRONA-DP KRONA 3" STAINLESS DOWNPIPE with RACECAT
1 KO-BPV Performance Bypass Valve Kit
1 FPR3.5 3.5 BAR FUEL PRESSURE REGULATOR
1 V-HOES SILICON VACUUM HOSE 30 ft
1 Poly Transmission bracket mount
1 SAS Sway bar kit with bushings
1 SAAB 55558696 Oil Trap
2 2008 used Cadillac CTS Calipers
4 Spacer bushings
4 CTS-V caliper bracket bolts
1 Fedorro Front brake pads
1 Akebono Rear Brake pads
1 Centric Premium Slotted Front Cobalt SS TC rotors
1 Centric Premium Slotted Rear 9-5 Aero Rotors
1 Techna-fit Braided brake lines
Still more to come.
Status
