LS1SSChris
Hello all,
I have a 2000 GTP with 133k miles, got the car done today after being down for a while due to LIM gaskets. The first few times my buddy and I ran the car it was running rough and died, was visibly burning lots of oil and was also throwing a P0300 misfire code. After seeing this we checked over everything again and all looked good, other than a leak (which stopped on its own) that was coming from the golden EGR tube (?) with the bolt next to it on the drivers side of the intake manifold.
Little while later we used a multimeter on the coil pack to see if we were getting a good connection from our plugs/wires and all was well. Here's where we got confused though, after starting the car repeatedly throughout the process it got smoother and at idle the misfire also seemed to have smoothed out some as well, no leaks or anything. So, we cleared the misfire code then drove it a few miles and it ran nice, still a slight misfire at idle but no noticeable oil burning. However, even though the misfire code is gone for now, it now has a "P0134 02 sensor circut no activity detected bank 1 sensor 1". Other than that though it seems fine.
What could be causing the misfire and what was the oil burning about? What could have made it smooth out? Oxygen sensor? Vacuum leak? Fuel?
We're stumped, thanks for any suggestions on what to check or any help.
