SgtMarshal
Active member
I have a friend who has some mad fabrication skills, and we discussed putting together a turbo setup. he said he would start with 2 front oem manifolds, and modify one of them to use on the rear. he also said if I left my car at his place for a couple weeks he would do the whole install, to make sure the fit and finish was good. we are planning on doing a T3 61MM turbo. the site I am looking at ordering from is www.on3performance.com, and the guy doing the fab work and installation will vouch for them. so far all the parts I have in my shopping car total about 750, and include the turbo, wastegate, blow off valve and turbo blanket.
my current setup is an xp cam with ported heads, 90 lb ls6 springs, and a phenolic air to water intercooler. I'm planning on keeping the air to water intercooler, but I will open up a supercharger case for more airflow.
I am planning on installing 130 lb valve springs, and a double roller timing chain. one thing I am wondering is that since I am already going to have the harmonic balancer off, and am going to a turbo setup, is there a good naturally aspirated harmonic balancer that I could use?
http://www.on3performance.com/
