GPSims39
Ok, most of you have seen my little saga in the General Tech forum, however this is now a trans issue, heres the low down:
Replaced Battery Tuesday 3/17. Car drove fine prior and after. Start car on Wed, horrible clacking sound from engine that faded in and out, trans shifted odd. Same thing going home, trans started to slip. Thrusday on way to work, lost all gears stranded on side of the road. When car is cold it shifts into gear and goes R1234 no issue, however there is a clacking noise, when warm no clacking noise, no gears, R-1 on shifter. Pumped out fluid replaced with Dex 6 and lucas, same result fine when cold, nothing when warm. Ideas? Thoughts? Prayers? Donations???
