Did you check to see if the angle still matches the rotors?
also, is that your needle bearings full of metal shavings? If so, you're probably going to want to replace those.
X2 on the needle bearings.
Also...porting a GenV is worthless...bench dyno proven.
I'm not gonna hog the gen V out like this one, I really just need to remove the H bar for my intercooler and I will probably smooth all the rough casting areas out. This was really only to get practice and mainly to see if it would even work... If anyone else wants to try it with a router I used all standard grade wood bits just at very low speed so they didn't heat up and burn
No...any '04+ car has the GenV...leave it alone unless you have TOTALLY ran out of things to do to it.
