All the questions. No answers
That's why I'm looking else where
Sent from my pager using Morse code. ... .. ... ....
Well I don't call much. More of an online person.
If your getting an hid kit then I would recommend morimoto, for 150 you get an amazing kit and a harness. They are very high quality compared to others
Quick question...
Looking into new HIDs, for my truck, and noticed you offer new "HYLUX" kits, that are 60 dollars more than your Precision kits, currently offered. Curious what, if anything, I'll notice differently by using these? Would also like to know if your HYLUX kits include a lifetime warranty.
Thanks.
If I were to but the 9007 kit (2003 GTP Limited Edition) would this just plug into my present housings, and give me HID high AND low beams? Could I also then later put them into a retrofit projector setup? Also, does the $80 include the relay to power the headlights from the battery? How will this affect my DRLs? And lastly, what is the cost to ship to me in Brandon, Manitoba, Canada R7B0R1?
Figured I'd pop in again and say that I've been running my HID kit for quite some time now and it continues to work flawlessly. I too was a bit skeptical at first, but the customer support I got though Paul's crew was much much better than other places I've shopped. I usually get compliments about my lights and I tell people a bit about them then point them in Paul's direction. Would definitely go back to DD if I ever wanted a second HID kit.
Yes, these bulbs just plug into your stock housing, I can't tell you if they would fit into an aftermarket housing, it depends on the housing itself. The relay is included with the price. And yes, the relay directs the power straight from the battery instead of using your factory harness. As long as your DRLs are on a different circuit, they won't be affected, otherwise you will need a warning cancellar. We do ship internationally, It will probaby be around $15 to Canada. If you add the items to our shopping cart and type in your address, the website will give you an exact amount. Let me know if you have any further questions.
-Garrick
What the difference halegon hi and Bixenon for bulb kind?
The difference between the slim ballast and the hy-lux can bus ballast?
Also on line it say $89.00
