Poly Mounts...
gotboost3
hey guys so i been hearing a popping noise when i go up curbs or come to a hard stop....i was on a site looking at the MSP poly mounts and noticed in the install instructions that the lips on the edges of the mounts had a longer and shorter edge...longer faces the motor and shorter faces the ground....i installed some used zzp poly mounts one day in a rush before work and i went back tonight to check to see if i did the longer/shorter edges correctly....turns out one of the mounts i did wrong and the mount had play up and down due to the shorter edge leaving space ... do you think this was the culprit to the popping issue or i was thinking loose cradle bolts....i havent drove yet since i corrected the mount just wondering yours guys opinion on whether or not you think that mount would make so much noise wen put in wrong like that
Could be...or the popping is your actual lower motor/transmission mount...might want to check them for tears/breaks, etc.
