Plz help ASAP
dboy187
Ok guys this is freakish weird I'm driving along all of a sudden dash lights go bazerk, engine wants to die rev up and it acts ok, little bit more lights dim and dash lights and mph and rpm gauges go crazy I am stumped and frustrated. Then sitting park running engine goes hay wire sucking air like no tomorrow, spit sputters it smooths out and then does it again and dies I have been HAVEING a problem with my battery when I shut car off it won't start per dead battery would all these problems b linked to the battery never had these issues until bat issue but I wanted to see if anyone else had any problems like this...
get the battery tested, as well as the alt. if one tests bad change it. clean the cable terminals up good, and check your grounds on the trans, should be 3 wires there.
Ok guys I will check everything tomorrow and report back an an odd thing I have since I bought the car is even with factory stereo there's a engine whine coming through the speakers
Well I did find a loose ground on the trans by the starter battery is toast so I'm getting ready to go get m other from my house and toss it in and see how it goes thanks guys
