Please help
GTP+007.JPG i have a 97 pontiac grandprix gtp i cant find out where do that plug go my uncle did a lim job on my car today but the car would only run if we hold our foot on the gas pedal we cant figure out where do that plug go can someone plase help
Yup. temp sensor under the thermostat on the LIM.
As for the running with only the foot on the gas, if the plug doesnt fix it you may have a big vacuum leak.
Under the thermostat like we said.
But here is a picture.
yeah lim job= a vac leak. check all the T's, and the fat vac line off the TB. it seems every one who does a lim job breaks a vac line or two. its common.
i re did all my vac lines for about 5 bucks, and that included 2 new T's, i used plastic T's its all thats out there.
i saw the plug to the main harness on top of the engine on the open pig tail. i knew that was the temp sensor plug right away.
ok i found the temp sensor and plug it up but it didnt fix the problem my car would only start if my foot is on the gas pedal but when i unplug my mass air flow sensor the car would stay running but it act like im constantly stomping the gas pedal to the floor
