Update...So everything is back together. I crank the engine and it feels like it wants to start but stalls out quickly. When I turned the engine by socket did I have to return it back to top dead center??
It sounds like it's not getting fuel or spark is cutting out, time trace down the cause. Make sure it has fuel pressure after it's primed and check all related IGN fuses.
if the gas pedal is hard to push you got its cable twisted up or something or hooked up wrong. or if it was getting sticky or hard to push before all this, the cable could be failing inside the housing.
if you got no fuel coming out the shrader valve your fuel pumps not working.
You know what!!? I have to check that plug out. I don't remember that I plugged it back in now that I think about it. But I don't think that would cause the car not to start.
So I had my mini scanner hooked up...No codes but 4 are incomplete...Cat, O2 sen, O2 htr, and EGR. Question..Does the vacuum line for the transmission and fuel regulator goes on top or bottom tube on throttle body? I forgot to take a pic of that when I took it off
new vac line is cheap. like a buck a foot at all parts stores. if you need t's or Y fittings, advance auto has the best selection. the rest got one lousy T and its huge lol
I have that big lousy T lol. A quick update...I checked the fuses and relays and they were all fine. I tried cranking it for the first time in a few days and it started to sound a lil better and then it shut off. Maybe it was 2 1/2 seconds. I took a pic of the tailpipe after I was long done with trying to start it and saw this: http://i349.photobucket.com/albums/q384/aoliver4mayor/IMG_20170207_133725_zpsaswdzi6t.jpg
Idk what that means and why it's just sitting there.
UPDATE..So I have fuel going to the injectors as I was testing the Schrader valve wrong. I also fixed the accelerator pedal as the throttle body was stuck closed because of carbon and the cold winter. I'm running out of options and patience. Don't know what to check for next...
Update..So my dad gave me a jump start and what do you know!!? The car started lol. Now my new issue is smoke coming from under the hood and the exhaust.
