CandyBlueta
Ok here is the vehicle info...
2002 GTP
Bone Stock
2 door
148k
Redfire metallic
Problem info....
I try and start the car and sometimes it will fire up first try, other times it will take between 20-200 turns of the key before it will finally crank and fire. When it doesnt start, there is no cranking or anything. just the click of the starter relay. It has power to all the normal interior things and what not. Also the keys go in and come out of the ignition tumbler just fine. no hang-ups there
The security light was on before this started happening and still is on. It doesnt flash, just stays on. It has the Pass-Key 3 system
There are 2 codes for the security light stored. They are:
P1629C- Theft deterrent Fuel Enable Signal Lost
and
B2955- Key Code Input is Short to Battery
The problem has gotten progressively worse in about a week. :th_thumb-down:
What ive done...
Ive done as much research as i possibly can.. i have checked all wiring in the steering column and found no frays burns or previous hack-jobs. Ive also replaced the starter and the battery. The passkey reset procedure doesnt work because the security light never "shuts-off" after 10 minutes. i even tried following the process to no avail...
New starter
New Battery
Wiring checked
I Dont get it... Help? :th_angry-censored:
2002 GTP
Bone Stock
2 door
148k
Redfire metallic
Problem info....
and
What ive done...
New starter
New Battery
Wiring checked
