Please hellp!!!!!!! Tranny problem gtp
Urquidez69
I have a 2000 grand prix gtp and one day I went to the store turned my car off and bought wat I needed came bak turned the car on applied the brake shifted into reverse and nothing tried all other gears and nothing it goes into like neutral stage they told me it was my tranny filter so I changed the filter and fluids brand new started my car and shifted into reverse and went in awesome so I took it out for a spin all gears went in so smooth even better then before the next day woke up to go to work turned my car on to warm it up waited lik 20min shifted into gear and nothing same thing again no gears wat so ever would go in I turned car off for lik 1min turned it bak on and shifted good I drove for about 15 feet then it went neutral stage again wat can it be? :( please help me!!!!!
When you dropped the pan and changed the filter. Was it full of pieces or just the normal coating of clutch dust?
Sounds a lot like a clogged filter. There's a few different things that could be at play though. Bad apply piston seal, gasket in the channel plate area blown out. etc.
Normal coating ig bro my old filter was pluged bad and i just put a brand new one pple i need help!!! Im sure it isnt the transmission it has to be a sensor or something else.
Unfortunately I'm unsure which sensor to suggest because there's only two and neither can cause you to have no gear engagement in either forward or reverse. As well, of your engine sensors, they can't do that either. They would cause banging into gear, delayed shifting...stuff like that.
Now, let's consider how this transmission works. It's all based off hydrauilics and fluid. Without fluid, no workie. Things that can cause this, bad channel plate gasket, broken pump shaft....See where I'm going with this?
A clogged flilter will typically drop enough crap off it when you turn the car off and restart to allow it to move a little before the filter clogs again. What was the old filter clogged with? Metal is about the only thing I've seen clog filters and obviously that's not a good thing.
