Ok, I am more than a bit late with photos, but check out the link below for what i have going on.
Update your browser to use Google Drive - Google Drive Help
1st we got the fuel rail situation sorted out. We used some steel line, and compression fittings to modify the stock rail. The front line around the SC snout is temporary, it will be replaced with some braided line when Im not trying to just get the car to run again. I checked the hood clearance and all seemed well.
2nd. My pop mad a stand off bracket for the IC pump so that its not wedged in place, and so that it can stand up and down.
3rd, you can see that the headlight opening was expanded, we cut and folded down some metal to give the hoses more clearance.
Interestingly, the injector wires on the back side of the engine wont reach. Tuesday, pop is going to extend them.
Pop is also going to make a T bracket to fit between the fender and the belts to hold the hoses in place to prevent any chance of them rubbing.
To do:
1. Wire everything back up, including lengthening the rear injector harnesses
2. Change the oil and add coolant
3. add fluid to and purge the IC
4. reinstall the front bumper.
5 Flash the ECU for the new injectors
Hoping to have the thing up and running thursday night.
Oh yeah, still no answer from ZZP on how to install their fuel logs, so come tuesday im requesting a refund.
