PK3 keys?
My 2001 GTP has it. Brand new key from the dealership cost me $30. I also have remote start and a regular key will NOT start the car.
whoever installed your bypass wired it wrong, the bypay uses a factory key and an extension antenna, but should only be active when the remote start is active, the way the system is set up in you car seems that the bypass is always active, thus making the security key pointless, with about 50 seconds and a screw driver you could probably start the car......
The quick remedy would be to open the dash, find the bypass and re-wire it so it is switched on/off by the remote starter :th_thumb-up:
Where is the "most likely" location (I should look) if any prior owner wanted to add a remote start module? PK3 (key) security system ? I know it is because I had to use the "30 Minute Relearn Procedure (Steps): This is for a "replacement" (new) key (no original available)"
mentioned in this thread :th_thumbsup-wink: to clear the blinking "security light".
