but it really doesn't run that bad. you can hear it, it's pretty loud. i've cleaned it and still can't see were it's coming from it hits the belt and gets slung everywhere.
If it instantly throws coolant all over I would assume waterpump with out looking at it.
Yup. Mine did it and am in process of changing it now, was just looking for some advice on the 2nd 1/2inch bolt on the power steering so I can remove the last bolt on the water pump :\
Thanks Red Devil...
I did this today...my engine bay would be dry, then i'd go WOT, park it...steam coming from engine, pop the hood, smelll anti-freeze and my motor would be soaked so I assumed it was the waterpump. ( 91K miles )
changed the waterpump out, didn't go WOT yet but maybe 4500 RPM's? drove maybe 10 miles, still slightly smell antifreeze and my heater is still blowing coldAny ideas? I think maybe it just needs some time to adjust and keep adding coolant as needed...
Also my bearing did not have any play ( just like when my wheel bearing went out ) but after I got the old waterpump out, I spun it really really fast and can hear a nasty grinding noise =O
water pump is easy peasy...don't let it intimidate you.
until the t50 socket snaps off in the s/c idle pulley, any ideas how to extract?
thnx again red devil. shouldn't the air work itself out? =P I'm lazy...
1998daytona, it was a 15mm on my car??
