    TIPS:
Phenolic Intercooler for your Gen3/Gen5 M90, L67/L32 3800's - LOOK INSIDE
Status
Not open for further replies.
Re: Phenolic Intercooler Gen 3 Gen 5 L67 L32 Eaton M90 SuperCharger 3800
Curious as to how much you would charge for a 1/4" Gen 3 Phenolic spacer? I know ZZP sells them for $120+ shipping but I would prefer not to buy from ZZP.
I will do $110 shipped if you can wait for me to order material and bolts!
I'm looking for a 1" Gen 5 phenolic spacer that is opened up like you do for your intercoolers. The bar has been removed under my supercharger but I don't want to go intercooled just yet. I do not need bolts or anything else, just the phenolic plate. I'm also not in a rush since I am currently rebuilding the trans and the motor is out.
My sig shows the spacer I had for my Gen 3. Thank you
Bought a tb adapter and some S/C supplies from this guy, everything is great! Prompt shipping and very good packaging. Everything arrived in perfect condition.
1/4" spacer
I had your 3/4 phenolic spacer on my ssic and it worked great I don't have the actual temp from my heat gun but I did notice a drop in temp I would like to install it with my s2
Just installed my phenolic/aluminum core on my Impala. SC was cool to the touch after a half hour spirited drive. Awesome product! Thank you.
$15 at Sams club. Looks like Amazon has them also. Need some zzp and wbs Intercooler people to do some temperature comparisons.
Need this! Compare aluminum water neck to supercharger!
Gen 3 intercooler w/ bolts $554
Gen 5 intercooler w/ bolts $554
New style is aluminum and phenolic. It is a full size core with more fins per inch than Zzp.
2-1/4" thick with working PCV
Pulley Pulley $90 (rental $50 back) fits in flat rate envelope for $6 return shipping.
L67 throttle body to N* with working PCV $80 w/bolts and fitting.
Gen 5 to North Star TB adapters shipped with bolts PayPal friend $80
SKF Bearing kits with Nye oil and green couplers $45 shipped USA
All prices include shipping to USA PayPal as friend or add 4%
Adapters
I haven't bumped this in a while. I make the best Intercooler period. It's phenolic and aluminum with working PCV ON STOCK MANIFOLDS.
I also have any part you need for a supercharger including stock or upgraded couplets. I'm cheaper than Zzp and still drive 3800's.
I have 1/4" spacers now. Should have 1" soon.
Has anyone had an issue with fuel trims being out of wack after the install?
I just installed my Phenolic full size. I applied RTV around any opening that would allow air in. On the LIM and SC.
There was an issue with my injector orings leaking the day of but I installed new ones and all is good.
So today after seeing my trims in the teens I looked into it. I removed my oil cap and my trims got even worse so I know the pcv system is working.
I poured water on the injectors and nothing. Next was around the SC/IC area of the snout and started misfiring badly.
Should I separate the IC core and re-rtv? I understand these come pre sealed.
New GM 3800 boost by-pass valves. Has the mounting stud.
$65 shipped for my PayPal friends.
Hey everyone. I really like Ed's product. But just be sure to RTV more to the left. Not right on the opening on the LIM. As you can see the IC didn't even touch that bead it and caused me a vacuum leak.
Looks like a gen 3 LIM, could have been opened up a little more on the pulley side. Glad it's running.
Ed, do you have the link to making your own pcv from the oil cap neck to throttle body? I can't seem to find it anymore.
Status
