    TIPS:
Phenolic Intercooler for your Gen3/Gen5 M90, L67/L32 3800's - LOOK INSIDE
Status
Not open for further replies.
Re: $450 Phenolic Intercooler Gen 3 Gen 5 L67 L32 Eaton M90 SuperCharger 3800 3.8 Li
did you just tap the filler neck? or does anyone know where you can get the pcv filler neck adapter from
I drilled and tapped the neck with a fitting yes. You should be able to pick a neck up from any junkyard or try to post up and see if anyone has an extra.
I used 2 brass barbed fitting from autoparts store or Lowe's. They were 1/8" npt. Plastic filler neck is pretty easy to tap.
I have a gen 5 done and machined manifold.
i already have a machined LIM.
so i just need the plates and core, and bolts.
I have Gen 5 bolts and intercooler. Match up your manifold to the outlet of the intercooler and open up to match.
Any available for gen 3? I might be interested in getting one soon.
I dont have any gen 3's currently, can have one ready to ship in 10 days.
I don't need it now. Probably in a couple weeks. Ill let you know. But i'm def interested
More material on order. Will have gen 3 and gen 5 available June 30.
Just received the core and all i can say is wow!! the craftsmanship is amazing!! cant wait to install it!
interested in a gen V will have the cash in a few days.
I have a gen 5 intercooler, bolts and a machined manifold ready to go.
It fits really well and looks even better. If anyone has any install questions I can possibly help also. The LIM provided was great also, coolant holes plugged and side opened up for better coolant flow. I would purchase from him again for sure. He has also answered all my questions super fast.
(I changed the way the plug wires run. They are now under the snout and the motor mount.)
Where did you get the material to make your own gaskets from?
This is the stuff:
McMaster-Carr
Unfortunately they still leaked air. I had to RTV the gaskets on both sides to make them seal.
what kind of rtv did you use and how to you spread it on the gaskets? Did you overlay it with ya fingers or just squeezed them out the tube? Im trying to seal my garlocs good. Might as well try that since making my own would still leak.
You can use gray or black RTV. I used gray and smoothed it out with my finger. I made sure it was in the right places.
thanks pure. I did that today and everything sealer perfect.
Status
